Bonjour,
Je viens de recevoir mon autoradio G13, commande SP-DA7364 du 12-05-2025 .
Tous semblent fonctionner correctement sauf la réception radio qui est de mauvaise qualité, perte du signal, son médiocre, l'appareil a du mal à trouver les stations FM.
Le RDS est correctement activé dans les paramètres d'usine, (j'ai aussi testé DTS sur Off et il n'y a pas de changement !).
La région Europe est correctement sélectionnée dans les paramètres d'usine.
Les connexions du faisceau d'antenne semblent être correctes.
La radio fonctionne correctement sur mon autoradio d'origine.
Avez-vous une solution ?
Merci
Est-ce que je pourrais avoir un retour de votre part concernant mon problème ?
Merci!
I have the same problem with my Dasaita G13.
The FM reception is unstable, stations can suddenly turn into static/noise, and switching to another station only restores reception temporarily.
I have already checked the antenna connections, tested RDS on/off, and the original Toyota radio works perfectly with the same factory antenna system.
After reading this forum, I am starting to think that there may be a defect or design/firmware problem affecting many G13 units, because there are quite a few users reporting very similar FM reception issues.
In your case the symptoms are also very similar: poor reception, signal loss, difficulty finding stations, while the OEM radio works correctly.
It would be good if Dasaita could clearly confirm whether this is a known hardware or software issue and whether there is a permanent fix or updated firmware for it.
@FUTRZAK
Hi FUTRZAK,
Please go to Settings > About machine and send us a screenshot about the current Build Number and MCU version.
@FUTRZAK
Please update the Firmware and MCU to the latest versions using the links below. Follow the steps carefully to complete the process.
Download Links:
① Firmware G13_V1(20260811):
https://www.dropbox.com/scl/fi/p5ocvu6u9o7x5ubgq765j/update.zip?rlkey=f88uayb0ezmkjn6qzqcz0ki3v&st=mhvj0vvb&dl=0
② MCU 4.18a:
https://www.dropbox.com/scl/fi/pt4jbm1nmeh1w7octd5an/hmcu.img?rlkey=uzkuhqaj20wrexuis49oyctgm&st=uq56dcqk&dl=0
Steps:
1.Download both files on computer.(keep names & zipped).
2.Copy file①② to a FAT32 USB drive (root folder).
3.Insert the USB drive into the device→ follow prompts → tick "Wipe data and format flash".
@FUTRZAK did you get the updates done and did it help with the radio issue?
Should I update anything to try to resolve my FM radio issues?
@Adam Woods
Download Links:
① Firmware G13_V2(20260811):
https://www.dropbox.com/scl/fi/puxm4pw9s4ypu1j6cxp32/update.zip?rlkey=6v9kkeufk3bkgfzpitt1rwchv&st=3y9hrx5d&dl=0
② MCU 4.18a:
https://www.dropbox.com/scl/fi/amw3k7mtkkxeb6zlbaxet/hmcu.img?rlkey=6g0yol3jrqa5s157fono6qv7s&st=4cf4ksmj&dl=0
Steps:
@Support Dasaita I got it done. It helped a little with FM stations but not much. Still a lot of static.
@Adam Woods @Adam Woods
We recommend performing the following steps before issue happened:
1.Go to Settings > Car > Factory Settings.
2.Enter the code: hctlog&
3.Reproduce the radio issue.
If the radio issue occurs, please retrieve the following logs via FileBrowser and share them with us:
*klog
*alog
